Re: 3.0 LT Mercruiser exhaust manifold water leak
There's isn't any water passages between the head and manifold, so I doubt it's the manifold gasket. Maybe one of the small casting plugs in the head between the head and gasket, but I kind of doubt that one as it's sealed with the casting plug and then the gasket should seal it off too.
Where exactly is the water leaking? From the center of the manifold and dripping down the manifold, under the manifold and dripping down the block, end of the manifold, riser?
Did you winterize it last fall (drain block, etc,,) and was it cold enough to freeze in your area this winter? Seems that right behind the manifold is where 3.0's like to crack.
Have any pics?
