I have a 1989 merc 3.0 and under a load it makes alot of spark knock, and if under a steady heavy load it will loose power gradually. New plugs and wires, new gas, added a can of carb cleaner in the gas, runs perfect otherwise. Help???
Nothing was "CURED", he only stopped the noise.<br />Like rodbolt said, he has now made it stop knocking, how he knows 2 or 3 degrees without a timing light is beyond me.<br />The next step (after a few more hours of running that way) will be to find out why the head gasket blew out. And that is a common problem with the 3.0L engines if the timing is off.Originally posted by trog100:<br /> Durana.. rubbish.. he has already cured his knocking.. now all he needs to do is to give his throttle stop screw a quarter turn to cure his slow idle..<br />
