i have a 1996 stingray bowrider with an alpha 1 gen 2 and a 3.0l merc. i have a no start situation where the starter engages and spins but doesnt catch! i have installed a new 750 cca marine dual purpose battery, new positive cable to the starter, new slave selenoid, new ignition switch, new starter. each component was replaced as it failed (or was believed to be failed). now the starter will spin and just whine. no grinding, but with a clunk from the bendix. the new and orig. starter both passed a computerized bench test with the same results in the boat. the orig. starter had the same symptoms and was replaced with the new starter which started out with the same symptoms and then worked and then the same thing....a whirling whine. even tried to shim the starter thinking that the clearance was too tight with no avail. motor will spin by hand. any and all suggestions would be of great assistance
