meder24
- Joined
- Aug 5, 2014
- 71
I had my '87 Thompson with the 3.0L Merc and Alpha 1 Gen 1 out for the first time yesterday. During the process, I began to have intermittent issues where I could not shift back into neutral from either forward or reverse. Some times I could not disengage from drive while other times everything worked normally. There was no consistent situation I could get the problem to replicate. It would work fine and then not work correctly both while moving and not.
This led me to believe I am having either shift cable issues or my interrupt switch is going or has gone bad.
I just verified my shift cable adjustments a few weeks ago getting ready for the season so i do not suspect those to be the issue. I did suspect maybe my throttle control is going bad but what I did next caused me to think that may not be the case.
While on the water (under load) and at home on the trailer, I tested the interrupt switch by pushing the lever to make contact. Neither time did the engine cut out while I had the lever pressed. If the switch were working, I would assume i would have had some reaction in one of the two cases.
I have not taken the switch out to test for continuity yet, but should I have had some sort of stall action in either case?
Any input would be appreciated.
