I rebuilt my 2 barrel mercarb spring needle, factory specs, set the idle speed, and have the idle mixture set about 1 1/2 turns out. I am very happy with the improved starting as it was leaking before rebuild.
However, the engine bogs as it never has before when pushing (not punching) the throttle. I now bogs under load when pulling. My top end rpm has suffered as well.
There are only three things to adjust, idle speed, idle mixture, and float level. This carb does not have the three notches for the accelerator pump.
Could my problems be caused by improper idle mixture? Could my problems be caused by a low fuel level in the bowl requirng float adjustment?
I have done searched the form, it seems all questions suggest other problems or rebuilding the carb. I have done both (new engine, EST, timing set right). Your suggestions are appreciated.
