Crazydave1243
- Joined
- May 12, 2010
- 26
Hello to you'll I have a 1985 thunder craft I?m not sure of the exact model the only number and the plate is model 162. The boat has a 3.0-mercruiser and alpha one gen one out drive not sure of the gear ratio. From the information that I have found on iboats the boat weights around 2000 pound empty, with gear and fuel, myself and everything I?m guessing the total weight is around 3300 pounds give or take. The boat is 17 foot long and is balanced well right now am running a Michigan wheel 14x19 prop which is aluminum. According to my tach I?m turning around 5000 rpm at 38 mph according to gps when I trim my motor up I do get some blow out. The boat gets on plane in no time; I?m not looking to pull a tube I want more speed. I never have over 4 people on board and we just cruise around. Thanks in advance for all the help.
