Coryb
- Joined
- Jun 12, 2012
- 51
Hello all!! I have a 90 sea ray with a 3.0 mercruiser which uses the mercarb carb. I did a tune up, changed all filters, and put fresh gas in the tank and it has an almost new fuel pump. I also rebuilt the carb because of dead/bog spot issues, which I still have. I did some research and made some small adjustments to the float. That seemed to make the dead/bog spot smaller, but it's still there. It won't idle right unless I have the idle mixture screw turned almost 4 turns out (which doesn't seem right to me) and now the engine dies out and stalls after just a few minutes of being at 3/4 to full throttle. It's actually stalled twice at almost the exact same spot on the lake that we use after running for almost the same amount of time. Maybe something to do with temperature? I'm not a mechanic and I am stumped as to what is causing the engine to stall out after a few minutes of being on plane and why I still have the dead spot in the throttle after a rebuild. After the engine stalls out it's hard to get it started again if it starts back up at all. It seems to be starving for fuel but I feel I have it set to run very rich. I'm sure could be a few different things but I'm not sure what else to check. Any direction would be great!
