Cldwell
- Joined
- Jan 20, 2013
- 30
I have a 2001 mercruiser 3.0 liter and for the first time I did not winterize the boat my self had it " professionaly done" got the boat uncovered yesterday and hooked water up to it and it started right up with no problems. Let it run about 20 min and temp got up to about 170 then noticed behind alternator a few drips of water. I killed it and checked oil no water in oil but there is a small crack on the block toward the front of the block same height as the drain plugs. Started motor back up an ran another 20 min and the amount of water that leaked out was less than 1/4 cup. Shop that winterized say nothing they will do about it I must have ran the boat after winterized which didn't happen. If any what is the best way to fix anyone had success with jb weld on a block? Or maybe some epoxy? Any help would be appreciated thanks
