Re: 3.0 Mercrusier in 1997 17ft Regal
Welcome to the forum!
Before we can even come close to providing a smart answer, we need some essential data from you. You gave some of the information, but this list below is found in a sticky at the top of the prop forum page.
ESSENTIAL DATA REQUIRED
When posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
3) Current prop diameter and pitch (required).
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight
FYI - Properly sized, the 4-blade will always give better hole shot and lack the top end speed. A 3-blade is always your best all-around prop if you are going to stay with a single prop and try to enjoy all aspects of boating. Going with SS is better when your HP is plenty; possible the 3.0L in a 17' Regal would benefit from the SS. If you have concerns about large rocks or fixed stumps coming into contact with the prop, then stay with aluminum.
Fill in the information above and we'll be able to help you out.
Good Luck!
