3.0 OMC ENGINE '79 ( Carb Idling)
gtaeza
I'm adjusting the idle of my boat 3.0 140-hp OMC<br />1979 (GM)if I set to 600-700 using the water hose<br />(muffs)the engine is almost died.<br /><br />Do I have to adjust the idle while in the water.<br />The timing is okey, compression is okey. Your recommedation are highly appreciated.By the way the carb is Rochester 2-BBL(2-jets)the air mixing and gas seems okey. Bt the way if you are facing the carb which one is the air left or right. Thanks.
MooseHootie
Re: 3.0 OMC ENGINE '79 ( Carb Idling)
They are both air. One for each carburetor bore. You should have them both adjusted about the same.
gtaeza
Hi MooseHootie<br /> Thank you for that information. Now, I know<br />ea. barrel have their own independent air adjustment. thanks
