Re: 3.0 Pertronixs Wiring, Bypassing Resistor
the way the ignition is wired in a points system is wire from battery first goes to your igntion switch. When ign switch is turned to run (engine running) full 12-14v power runs from the ign side of the switch to the engine where it connects to either a ballast resistor or to a resistor wire. Then this wire connects to the + side of coil, and this resistance drops the voltage down around 9v (when engine running) to prolong the life of the points.<br />For the start assist, when you turn ign key to start (engine NOT running) full 12v battery power goes to starter solenoid to activate the starter, but from the solenoid this 12v power paralles off and goes to the + side of coil, your 2nd wire on the coil + side. This is the only time the coil should see 12v, when starting the engine. When you release the key from start to run, coil no longer sees 12v power because it now comes thru the resistance as described.<br /><br />with the pertronix with flamethrower coil install:<br />remove the 2nd wire on + side of coil coming from the starting side of the ignition key switch, you don't need it.<br />Trace back from + side of coil to either resistance wire or balast resistor then to ignition key switch run side. All you do is take the resistance out of the ciruit, so the wiring simply goes from ignition switch run side to the + side of coil.
