3.0 popping noise
LilRedNeckGirl
Re: 3.0 popping noise
its a bit hard to hear on the utube vids, but to me it sounds like a click. I would look at the belt driven attachments, @ alternator especialy. see if its heating up/ seazing momentarly.
typicaly, a "POP" is a carb backfireing for whatever reason, but yours sounds more mechanical. Easiest fixes are in the belt driven arena. try useing a broom stick pressed against your ear to narrow it down. put the stick end on each part of the engine in a SAFE location, then listen with the other end to your ear. that click will be easily located with this method most of the time. ( useing a solid wood stick of course, them hollow dollar store broom sticks just dont cut it. )
rethredge
Thanks, I'll check that. I noticed that often when its making the click I can see fog coming from the engine through the tube that goes to the air intake. I think you can see it in one of the videos.
