I have a 1989 3.0L
The boat was last run about a month ago and the only issue was some slight missing at lower RPM's. But otherwise I had plenty of power to pull tubers with people on the boat.
Fast forward to this past weekend I took the boat on a big trip and experienced problems.
Very little power at WOT
Missing at lower speeds
Would not plane out most of the time
I added Seafoam and the problems went from all the time to most of the time. Towards the end of the trip i would give it full throttle and then it felt like a delay then power would kick in sometimes. Once at cruising speed it ran great. If I came off plane and then tried to go back on plane sometimes there wasn't any power and it would not plane out.
Things I tried
Visually inspect carb and fuel liines - looks good
Spark plugs and wires look good and are 2 years old
The fuel filter in the fuel pump looks good and so does the mesh one going into the carb
The carb was rebuilt 5 years ago
I ran through about 20 gallons of gas with this issue on fresh gas
Engine starts and idles fine
I do not have access to a timing gun or compression tester. But if people tell me these things are necessary I will purchase them.
Some other items that may or may not be related
Tachometer is all over the place. Sometimes it's accurate and sometimes its thousands of rpm's off
When I winterized it, I put a new 140 thermostat in it. Should it be 160 thermostat?
Thank You
Things I tried
Thank You
