kjhowayeck
- Joined
- Apr 4, 2005
- 15
I have 1987 3.0 Mercruiser 4cyl 140 hp, Found out that I had a blown head gasket and I decided to go into it myself with help, but have run into a few problems getting the motor to run correctly. After we put the head back on we adjusted the head bolts in the pattern and then adjuster the lifters as well. Started the engine ran rough. Took the valve cover back off and adjusted the lifters as the Manual said by finding zero lash and turn a half turn tighter. The boat starter idled okay and decided to put into the water for a test. When we did the boat shuttered and idled hard. Disengaged The engine the engined reved good and sounded great, but engaged the engine struggled and had no power. We thought to take it apart again and try to adjust the valves again by the advice of a boat mechanic. This time we tryed to go 3/4 a turn past the zero lash. After this the boat turner over and over again before it backfired to times in a row. Seems we are missing something. Does anyone have any suggestions about the valve adjustment, turn pash zero lash, or special tools that would make it easier to do. I just can't understand how so much engine can have no power now.
