CapRedbeard
- Joined
- Jun 8, 2021
- 39
Hey all. I believe I have a seized power steering pump. I noticed engine temp climbing on the lake and shut it down. I started it back up with engine compartment open and saw the belt was static. I towed back in and now I’m in the garage.
After removing the belt, the circulation pump and alternator rotate freely but the power steering pulley is frozen. The raw water pump is on the cam shaft in this engine. I’m planning on ordering a replacement power steering pump unless this model has replaceable bearings or something.
I thought this was a good time to check the impeller, so I pull it apart and notice it looks like the previous owner used a gasket maker on the pump housing. The impeller looks to be in fine shape, but should I just order an impeller kit with gaskets and all to be safe? I assume I need to meticulously clean up the bits and pieces of the gasket maker inside the pump so they don’t work into the engine, correct?
I attached photos.
Thanks in advance for your guys knowledge!
I attached photos.
