gator fan josh
- Joined
- Oct 7, 2012
- 54
Having trouble with my starter on my 2000 VP 3.0GSPEFS. Last week I was out and noticed the starter was making a grinding noise. So I pulled the starter and it appeared that the ends of the pinion gear was worn. I had the starter rebuilt by the local recommended shop. I put the starter back on and the engine cranked fine with no noise in the driveway. I took the boat out and again it cranked fine at the ramp. While I was out the engine stalled and when I went to crank the motor all I heard was the starter spinning without engaging the flywheel. I got towed in and made it back home. I removed the starter and everything looked ok. I inspected the flywheel and it looked ok to me, I have attached a picture of it. When I put the starter back on the engine it would crank the motor for as long as I would hold the key. After I let off the key and tried again it did the same thing of spinning but not engaging. I measured the battery voltage to be 12.55V and I measured resistance on the positive battery cable and the starter chassis to the negative terminal and they were both less than .1 ohms. Does anyone have any advice for me? I have tested the new starter with jumper cables and a screwdriver on my boats battery and the bendix comes out fine. To me the only other thing would be the ring gear on the flywheel but I hate to pull the motor in the middle of the season.
Thanks,
Thanks,
