Simoniz
- Joined
- Dec 30, 2007
- 242
My boat is craned in and out of the water for the summer and winter seasons, so its a bit difficult and expensive to get it on dry land for maintenance at ad hoc times during the summer.
Despite this, Ive neglected to replace the (OEM) raw water impellor for 4 years and now that the boat has recently been put into the lake (freshwater) it seems to have a low speed overheat, with very little water being pumped up to the engine at 800 rpm idle speed. At anything over 1000 rpm it seems OK with the water temp gauge steady on 175 F with pressure felt in the circulating water pump to thermostat hose and the exhaust system checked with an infra red gun shows 50 deg C (130F). Cruising the boat at planing speeds is also good, and when I lean out over the back, the water coming out of the exhaust relief ports is a comfortable hot temperature, about right for hand washing.
Even though I know Ive gone over the recommended interval for replacing the impeller, Im surprised that its gone bad so quickly, but I suppose the vanes have taken a permanent set, and theres enough clearance to allow the water to take the easiest course at idle speed. The guy in this video says he's run his drive for 320 hrs in 7 years on the original impeller, and that he would put a 2 or 3 year old impeller back into the drive and not replace it.
forums.iboats.com
I don't suppose it will get much worse with a bit of running (might even improve as the impeller recovers from sitting for 5 months?) and I propose to use the boat this summer season (20 hrs) before replacing the impeller in the autumn (fall), by not running it at idle for more than a few seconds at a time, and monitoring the temperatures closely. The boat has an exhaust overheat alarm which sounds at 70 deg C (170F), and during normal running, this doesn't go off.
Anyone see any problems with this? Obviously in an ideal world, Id get the boat out and replace the impeller, but to do so would cost me nearly $300 for the lift, and Id like to avoid that expense if I can.
Finally, do impellers have a shelf life sitting in the box in the shop (constant room temp)?
Thanks for any opinions / input!
help help help overheating Mecrusier
1998 Merc 5.7 with Alpha one outdrive. The boat overheated on its first use. I changed the impeller, and it overheated again. I took it apart impeller looks good but i am going to replace it again anyway. I don't know where to turn to troubleshoot. I just realized it looks like my motor...
