Re: 3.0L blown head gasket.... how common?
Used, S/N OL083288. I'm assuming it has never been replaced. <br /><br />My concern is that the boat was running rough at idle the last time I had it out (ran great WOT but difficult acceleration), but it could be bad gas or other(?). I didn't hear any pinging, but... I wasn't listening for it. I haven't had a chance to do any troubleshooting, but now of course I'm fearing the worst. <br /><br />I'm going to try to do a compression check this weekend (along w/ fresh gas and carb cleaner) if I can find time and the weather cooperates. Are there any tell-tale symptoms that will let me know for sure one way or the other? <br /><br />If it is my mind playing tricks on me and the head gasket is fine, should I back the timing down (0 deg BTDC or the recommended 1 deg ATDC) and tighten the head studs to 95 lb.-ft. as a precaution to help prevent this from happening in the future?
