OK, thanks it`s running fine now
Regards
Affa
I hope you did the preload on the lifters, because if you didn't, somewhere in the near future, you will start to hear tapping (a lifter went loose), then you'll hafta take the valve cover off, and adjust them all over again!
I'm old school, and learned to do this with the engine running on small block chevy's before any other method, I could do it in my sleep! I know it's messy, but a sure fire way of getting them right!
Now, if you want to use this method, loosen up all the rockers till you have a bit of play in them, start your engine, and let it warm up (valve cover on) no damage if they're a bit loose, but you don't want them tight! once warmed, take off the valve cover, and listen,,, then begin turning each rocker nut down slowly just a little at a time, till the noise stops,,, give it a few seconds to adjust, then turn it down slowly another 1/2 a turn, and you're done,,, Then move on to the rest of the rockers, and do the same thing. You will easily be able to do this, and set all your valves just by stopping the clacking noise. Any questions?
