Hello all, Thank you in advance for your responses!
1986 16' Sea Ray MCM I/O 140 4cyl. 181 CID S/N A394995
MerCarb 2bbl (1 idle adjustment screw)
Block S/N 2770087 2 85
Alpha 1 Out Drive S?N A530190
It all started when the Boat sank last year after the shift cable bellow sprung a leak!
The boat was given to me after that! I removed head and got all water out of block and changed the oil. Boat sat for the winter in my garage and dried out real good.
Last week I replaced the head gasket, plugs, starter and new gas (the tank has a lot of water in it!)
Today i was ready to try and start it, Put the muffs on started the water and hit the key. It would not fire.
Checked fuel flow to the crab and all is good, but no fuel squirting into carb barrels.
Removed the carb opened her up and she was full of white residue. Looks like corrosion.
See pic
Cleaned carb up real good and cleaned the pump assembly as well.
Put carb back on and now I have a nice stream of fuel squirting into carb when I pump the throttle.
Now that all said and done! SHE WILL NOT STAY RUNNING!
I pump the throttle to get gas into carb, it fires idles for a few seconds and quits. Will not fire back up unless i pump the throttle again, then same thing.
I've tried pumping the throttle when it is idling but still dies. Like it only stays running until it burns off fuel i pump into carb.
Any ideas? Was thinking about pulling carb off again and checking the float level.
Free boat i cant complain. but here in Michigan the year is coming to an end. I would like to try and hit the water.
Once i get it running I have to tackle the bellows and going to replace the impeller while i have the out drive off.
Thanks again, and look forward to your responses.
CHOBES
See pic
CHOBES
