I have a 99 bayliner 1750 capri with a 3l. I just adjusted the shift cables because it wasn't going into first gear. But I didn't notice the interrupter kicking in when shifting in and out of gear. If you push the interrupter button in it well stall the engine. I did this while in the driveway hooked up to the muffs. Should it be doing snything different. Also when I put it in gear there is a quick grind is this normal out of the water? Thanks
