I have a '05 Four Winns with the 3.0L Mercruiser motor with the "new style" shift interrupt switch (Motor SN 0W039120). Bought the boat last year and the previous owner stated that he just put a new shift interrupt switch in it. When I had the boat winterized last fall they stated that the switch wasn't working and asked if I was having any issues; I said no. Fast forward to this season, and now I am sort of looking for it, and yes, I am in fact noticing a 3-5 second delay in the prop coming out of gear when shifting into neutral. Figuring the old owner was full of it, I bought a new switch, installed it and motor does not cut out or stall when pressing the brand new switch. Assuming I don't have two bad switches, I called the marina that winterized it and they said it could be out of adjustment, or could have been disconnected ect. ect. They weren't sure and they would have to diagnose it and may have to pull off out drive to re-adjust, and also mentioned I may have stretched out the shift cable if I don't take care of this issue (then I would definitely need to pull out drive).
Anyone have insight? Is there a way to "re-wire" that shift interrupt switch back into the system? Why would someone purposely disconnect it? Should I bite the bullet and let the marina shop diagnose it? Or are there some steps I could take to trouble shoot it myself?
