Re: 3.0L Timing chain cover from parts store?
the crank thrust bearing is a one piece sleeve bearing for not only the crankshaft main bearing journal but that journal width is carefully machined and flange, the normal lateral thrust loads(foe and aft) are controled by the flange to flange oil clearence. normally someting less than .007". when you whack the balancer ,and sometimes its the only way, the crank,if not supported from behind, transmits the force of the blow, remember newtons law here, to the soft babbited bearing and can and sometimes does increase the crank endplay.<br /> I have witnessed it.<br />its a fairly tight fit but DO NOT oil it or odds are it will leak. if you do oil it then carefuly clean the oil off and run a bead of silicone areound the ID of the balancer and the crank snout.<br /> you have to be careful tossing out just 2.5L as GM manufactred not only the 153 CID they made a 151 CID. the 151 was used in the late 70's mid 80's and other than being manufactured by GM shares no common components with the 153 and later 3.0. the 153 was used in the marine application.<br /> the 151 never made it.<br /> I have not found a suitable method to insure a leak free joint without removing the oil pan so usually the engine is out anyway.<br /> I know somefolkws try to cut the seal ends and pooker it up with silly cone but it normally starts dripping a bit. so now they have paid mee 500 buxs and have an oil leak that they can see on that clean fiberglass deck. ya think they are gonna call me? who pays for the second try ?<br /> thats why I perform the steps in accordance with the manual and with factory approved parts and accessories and lo and behold it works right the first time everytime.
