3.0L volvo penta
mhunt
Hello all, new to the forum, new to boating.
I'm looking to possibly purchase a 17' 1995 sunbird runabout with the 3.0L volvo penta engine. I want this boat for mainly recreational use, i.e. tubing and wakeboarding and just 'running about'. I'd love to be able to afford a v-8 powered rig but that's not in the budget at this time. Will the 3.0L suffice? Will it pull a 185lbs wakeboarder? What kind of performance modifications are out there for this engine, if any? Finally, what's the word on Sunbird.....reliable or crap? Thanks in advance.
-Matt
Limited-Time
Re: 3.0L volvo penta
Many a boater has started out with the 3.0, and lots have stuck with it. My suggestion is to lake test the craft loaded as you would for a day on the lake, coolers, friends, gear, and whatever else you'd drag along. And I'd go as far as strapping on a board an doing a set. That should answer all your questions. If the seller is not willing to allow that, find another seller.
Probably,....... That's a pretty Small boat..........
Probably,........ But,..You Might have to leave a few of the Spectators on shore.....
None,.......... Don't even Think about it.........
It's an Entry Level boat............. Doesn't make it Bad,...... But it's not known as a Quality Craft......
Thanks in advance.
Ayuh,......... Your Welcome,....... Anytime.......;)
4winnsskipper
I have a 17foot four winns with only 30 hours on it, it pulled a 200lb skier out of the water no problem with 3 others on board, and 22 pitch prop!!!!! I picked up a 19 pitch prop and the boat just jumps out of the water like a bat out of hell, although i cannot go full throttle otherwise it will over -rev, i use this pitch for heavy loads / skiing. Most of the torque will come from how you prop the boat, 4 blade, 3 blade, and pitch are really important. Its really easy to swap props, so your 3.0L should have no issues on a 16-17 foot boat...plus working on the inline 4 is CAKE!!! i love mine!!!
Robj
I have skied behind a 40 hp outboard at 3000 feet, I weigh 200 lbs. It was able to get me up. Your 3.0 should have no problems pulling a wakeboarder or skier. Plus the Volvo makes a great drive that should serve you well.
Have a great day,
Rob
