3.0LX Mercruiser Blower Schematic
Maxum88
Hi Guys,
I'm in search of a schematic for the blower assembly for a 3.0 Mercruiser. I have a 1995 3.0LX Mercruiser. Mine was intermittent now it won't turn on. I put 12 volts to the blower and it turned on just fine. I swapped the wires with the bilge switch and still nothing (but the bilge did work on the blower switch)...I'm getting 12v from the black wire...I ohmed out the yellow wire from the switch to the blower and read less than 1 ohm...I also read less than 1 ohm from the black wire from the blower to the negative terminal on the battery and the negative bus bar. There is a red wire on the switch that I could not trace...I also disconnected the harness under the switches and cleaned what corrosion I saw...still nothing :facepalm:
Thanks in advance for your help!
-Tim
Don S
Re: 3.0LX Mercruiser Blower Schematic
Mercruiser makes engines and drives, not blowers. Assuming you mean the bilge blower, I will move this over to the electrical forum. Post a picture of your blower if you can.
