3.7 Lt headgasket test?
Murph d
Is there a quick and easy head gasket test to perform on a 3.7 Lt Mercruiser ?
ricovw
Re: 3.7 Lt headgasket test?
Yup. Do a compression test. if you get a low reading on a cylinder or 2, you have an indication that something is wrong. You would still have to eliminate a couple other things, such as valves.
Murph d
Comp. test shows #1/125psi #2/135psi #3/132psi #4/130psi
The reason I thought I might have a problem is the fact that I had pressure in the coolant reservoir when the motor was running, moments after initial start up , after sitting for 4 months. Is that normal?
Thanx for the tip on comp. test
Ayuh,... If it continued to build pressure, blowing the coolant out,...
That would be a Problem....
If your system is tight,.. it coulda been holdin' pressure the whole 4 months...
Don S
A compression test won't tell you much if it's a small leak.
A leakdown test is the only way to test the cylinders. Top off the coolant, leave the cap off. then pressureize each cylinder and look for bubbles in the coolant tank. No bubbles, no leaks.
