Re: 3.7 merc 1987 water in back cylinder
On those engines, either your exahust manifold or your riser will be aluminum. I'll bet a nickel that one of them is so corroded that it's allowing the water to leak in the exhaust chamber. And since it's at the rear of your motor, the water lays right there. And as Don points out, when the exhaust valve is open on #4 it runs in that cylinder. Common issue on many marine engines, especially that one.
