I recently put a new shift cable on my 1988 3.7 mercruiser. It now seems to shift into forward or reverse about right.
It does not seem to me that the shift interrupt switch is killing the engine for a split second when it needs to. **My understanding is that should ONLY happen when taking it out of gear in either direction, not putting it into gear??.
1 Question: Exactly how do you adjust the situation so that it interrupts the motor at the exact time....I am not sure what the step by step procedure is, or which cable to adjust to make it do that., top or bottom on the shift assembly?
Any photos or explanations helpful.
Thanks
Thanks
