Hello all. 3.8 mercruiser with an alpha 1 drive. Had the impeller replaced at the beginning of the summer. Went out with it 5 times. No problems, except the carb had a big flat spot in it. I had the carb redone and completely gone though by a pro carb builder and had it set up for my area and altitude. I put the carb back on and started it for a couple of minutes to make sure it would start. Took it to the lake the next day and launched it. Got about 1/4 mile away from the boat dock and was in the red for temp. Shut it down and spent the next 3 hours trying to get back to the boat dock. I took the hoses loose on the water and there was no water in the block. I was dumping water into the open hoses with a can. I started it a few times and the water pump on the motor was circulating water. It just seems there is no water coming in from the lake. Can putting a new carb on cause this? The boat has never over heated before. The only thing can think of is the 2 minutes that I ran the boat with the new carb damaged the impeller. Can 2 minutes do that running dry? If that is the general consensus then can you point me to a link to change the impeller? (I had it done by someone last time and did not do it myself) I have searched the sight but haven?t found the link yet. Thanks.
