Re: 3 bank charger on 2 batteries
Hello;
If you are trying to charge all three batteries while the engine is running :
Starting battery ---- leave hooked up as normal for most users.
http://continuouswave.com/whaler/reference/chargeBattery.html
"The typical marine lead-acid battery has a terminal voltage of "12" volts. The battery actually consists of six cells wired in series, each cell capable of producing 2.15 volts, creating an aggregate voltge of 12.90 volts. When a cell is approximately half discharged its voltage will be 2.03 volts, and the battery terminal voltage will be down to 12.36 volts. When the cells are almost completely discharged their voltage will be 1.75 volts or less, and the battery terminals will be 10.5 volts or less. "
I recommend any charge even if it is not sufficient to fully charge the battery to reduce sulfation.
To charge the other two batteries if not hooked up 24-volts or 48-volts :
You can use a
battery isolator like used on most motor homes:
The charging lead is usually the middle leg and the other batteries hook up to the other legs. This will feed the batteries when the boat is running and charging and isolate the two other batteries from each other and from the charging circuit.
Heavy use of the house or trolling motors can pull down your starting battery in this arrangement --- there is a 0.6-volt separation which is usually enough.
If heavy use of the auxiliary is likely then hook the charging circuit to the center lug and starting battery to bat 1 connection and auxiliary battery to bat 2 connection.
Here are some marine grade parts --- I do not know this site just a quick lookup for you
http://www.beiterbattery.com/marine-battery-isolators.aspx
OFM
