Re: 3 blade or 4
Todays 4 blade props are often faster than the same design 3 blade props. They dont run at the same X deminsion. If youre talking about the same design style, the 4 will run higher. If you run a 4 blade at the 3 blade height you may lose some top end.<br /><br />Now, if you start talking about the large diameter 4 blades, like a 4 blade Lightning, you can run even higher. And get more lift, speed, holeshot, economy etc. Usually a good 4 blade will carry the boat better even in mid range.<br /><br />What kind of boat do you have? Does it have a jackplate?
