3 blades or 4 propeller for 1988 17.3 ft 4.3L OMC Cobra?
houstonnoob
OK as you can see my prop's picture from other post in here and I am new to boating. I am getting a new prop, I am thinking of changing from 3 blades to 4 blades just because it seems better looking (<==LOL). I am asking anyone with experience of switching 3 blades to 4 input with 4.3L engine. I am sticking to 14.5 x 19p either 3 blades or 4. Thank you.
From iBoats new propeller section:
"3 blades... or 4?
We recommend 3-blade propellers for recreational boats with 3, 4, and 6 cylinder outboards and I/0 engines.
3-blade props provide good "hole shot" and top-speed performance.
We recommend 4-blade propellers for bass boats and boats with high performance hulls running high horsepower outboard engines.
Compared to 3 blades, 4-blade props provide better "hole shot" performance with less steering torque and less vibration at high speeds.
When switching from 3 to 4-blades, generally a 1" pitch decrease is required. So, a 21" pitch 3-blade prop is replaced with a 20" pitch 4-blade prop. Pitch is increased when switching from 4 to 3-blades."
Texasmark
Re: 3 blades or 4 propeller for 1988 17.3 ft 4.3L OMC Cobra?
If you have the engine to swing it, a 4 will have more blade to water contact, hence better hole shot. In addition it will hold up better at lower speeds, just above planing speed when you just want to putt around. Agree with the 1" drop in pitch rule of thumb.
An I/O with the 4 cycle engine sitting right against the transom, weighing 800# plus out drive, usually fuel tanks there and or batteries, usually jump seats adjacent to the engine cover which people just love to sit in translate into a lot of stern weight. Just like a bass boat trying to get all it's stuff on plane with it's setback and all, it is a big job and a 4 blade can handle it better.
Mark
houstonnoob
They are about the same price give or take few dollars. I'm going with 4 blades, Thank you.
