Re: 3 Blades Recommended for IO's
Hello Lastfin and welcome to iBoats! There is no single answer for every application; thus, you're not finding it.
Please review the top of the Prop topics section for the information necessary to assist with prop changes. There are several questions about your current setup, many of which you've identified, but still missing 1 or so.
In general, the 4-blade will give better hole-shot for the pulling of toys, and your top speed may go down. The in general applies as I think you're already aware. Provide more information and you'll get very good explanations.
Good luck!
The sticky I mentioned includes this text:
ESSENTIAL DATA REQUIRED
When posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
3) Current prop diameter and pitch (required).
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight
I think you've been given plenty of information regarding why the 3 or 4 blade is used in different applications, but I don't know that you've determined what direction to take for your situation/setup. As has been done, many directions (all good information) have been discussed, but without the "ESSENTIAL" information from you, you're still not going to get the best advice for your next prop.
Get back with us on your current WOT throttle rpm and if your 21P AL is in great condition. This matters A LOT.
