Should I change plugs to the Champion vs NGK?
Wi / Il boarder area, anyone know a good repair shop?
I noticed a very slight leak in the top carb bowl so I replaced that gasket. But that would of been #1 & #2 cylinders.
No, it should be all dark
Compression is at 120 on all 4 cylinders. I give up at this point as I have done what I can and appreciate the help. I found a guy (2 Hour Drive) that will look at it and repair it for a considerable amount less then a dealer. Wish me luck!Have you checked the compressions? 3rd cylinder?
Is the problem that it is running rough?
My bet is bad bias in switchbox as coils rarely fail on a Merc
