Hello. I have a 3 hp jw 14 that will not start. I haven't really tried to troubleshoot it too much. I thought I'd ask you guys first before I proceed, because I'm baffled. Last year I put a carb kit in and it ran great ( in the barrel ) when I attached the motor to the boat, no go. Really ??? I mean it would start right up and idle very low, and it would throttle up nice too....... in the barrel. But when I went to use it, I couldn't even start it !! I've got great spark to both plugs. They're getting wet ( but not soaked ) in fuel. Compression was always very light ( easy to pull over ) but ran nice. I'm pretty sure I don't have the plugs crossed. I've monkeyed with needles and tried different settings, but no go. I can start it, but only for a split second. I seems too me, that it's deprived of fuel ? My Pistons have some carbon build up, and my compression tests are = , but only 50lbs. That seems a little low to me too, are my rings stuck ? What confuses me is its always pulled over easy....... yet started right up. Fuel was fresh and clean. Any suggestions ? Thanks so much in advance.
