Hi, another carburetor question here, I've got my carburetor rebuilt, including the removing the core plug, cleaned the fuel filter and replaced the gas line, but still having trouble with getting and keeping this motor running. I noticed the slow speed (and only) needle valve on it is somewhat worn and grooved at the tip, but should that be giving me this much of a problem? I had it running for a while but only with full choke and since i tried to adjust it to run properly, I can't get it to stay going. I have it initially set at 1 and 1/2 turns out.Part of me is tempted to drop in an identical carb I have from another one i have running like a top (thanks to iboats for that advice too by the way), but I hate to go that route if there is a simpler solution. Thanks.
