I have a 90' Ranger 361V bass boat with a 04' 150 HP Mercury Optimax.
which 3 and 4 blade SS prop would get me the best performance?
Prop brand & dia & pitch please.
Thanks
Rangr90
Howdy,
Welcome aboard!
It's near impossible to pretend buying a perfect prop on first try for any application, usually is dialed on second if not on third try, who said boating was a cheap water sport. LOL!!
This is quite true!
One way to a "starting point" is to find an identical boat, similarly loaded with the same HP. If you cannot find one, go to the OEM manufacturer to determine what they recommend. This usually won't get you the perfect prop the first time, but you'll be close.
Once you're "close", you can then try different props (3 & 4 blade, aluminum and/or stainless) to refine.
Usually you cannot do this unless you go to a prop shop that will allow you to try different props.
You have to buy from them though!! Don't try different props from a shop and then buy somewhere else to get a better price!
Just about all the engine manufacturers recommend selecting a prop that will allow the engine to operate in the maximum recommended RPM range at WOT (Wide Open Throttle)
In general, you want a prop that will give you an RPM in the MAX range @ WOT for your engine (I.E. 5500-6000 etc) when you have the boat loaded (fuel, gear, people, dogs etc) where you'll operate most of the time.
If you want max performance, select a prop that gives you MAX RPM (or close to it.) But understand if you do this lightly loaded, It may be a little "doggy" when heavily loaded (if you ever load your boat to MAX gross wt)
OTOH, if you "prop" the boat for absolute MAX gross wt, (max RPM@WOT) and you always run around lightly loaded, you will be hitting the RPM limit at less than WOT (or the rev limiter if installed) at WOT
Since many people like to have spare props some will have props that will work for both
3 blade props will in general be best for all around use (with best top speed)
4 (or more) blade props will generally give better hole shot (and maybe slightly better fuel consumption at medium speeds) but not the fastest top speed. More blades (or blade area) in the water pretty much equates to more parasitic drag. reducing top speed
Make sure the engine is in good, tuned running condx, and you're using good fresh fuel before you try different props.
Cheers,
Rick
