3 or 4 on a 92 Force 90Hp
bkhealey
Hi everyone, I have a 3 blade 13 1/2 prop on my 1992 bayliner with a 90 HP force. with just me I can get up to 38 WOT. With a 3 people and a skier it's a little hard getting them out and going. I also like to cruise with 6 friends every now and then and want to smooth it out. Would like to get up on plane faster. Don't care if I lose a few MPH on the top end. Looking at a 4 Blade 15 pitch prop. From what I have been reading this should be just about right. I was told I would want to drop to a 15 when going to 4 blades. That I should lose maybe 2-3 MPH. Does that sound about right?
Thanks!
Brian
steelespike
13 1/2 sounds like a diameter? can you give us your diameter and pitch.
We need to know the prop size,rpm and gps speed.Your present rpm and speed would help determine
Your prop selection.
batman99
My previous Bayliner 1700 with Force 120 I4 motor had a 3-blade 21 pitch. Way too sluggish on the bottom end. I replaced with 3-blade 19 pitch and it was still too sluggish on bottom end for water sports. I then replaced with 4-blade 17 pitch and was pleased with it. Exact same boat with replacement Johnson 115 V4 motor came with 3-blade 19 pitch and I found it a little sluggish on bottom end. Me thinks a 3-blade 17 pitch would be perfect for average person "medium weight load / long distance cruising" usage. For our Johnson V4 motor (which likes higher RPMs), I'm now currently replacing with 4 blade 15 pitch - since we do more water sports than long distance cursing. 4-Blade is most often better for water sports / heavy weight loading usage.
Long mumblings short.... Do focus on 4-blade that is 2 pitches lower than your long distance cruising 3 blade. Depending on your daily usage, install the 3-blade or the 4-blade. Only takes a few minutes to swap out props. Yes. A smaller size pitch 4 blade is a littler higher on RPMs a little harder on fuel but bottom end increase (for water sports or heavy loading) is worth it... This approach works for my Bayliner... Hope this helps...
Sea Rider
If like skiing should do it with just driver, a spotter if needed and skier and go for a prop that achieves full wot rpm range for that engine on flat calm no wind water cond. Get another prop to boat with 6 to achieve at least medium to max wot rpm. Can't do sports + boating heavily loaded with just one prop, unless it's a adjustable pitch prop for different boating scenarios.
Happy Boating
SkiDad
my boat will hit 40 with a 19" pitch - fine pull for combo skis but not good for slaloming - 17 is fine for slalom as long as I only have 4 on board. i have a a few 15 pitch 3 blades and they pop multiples skier up with a full boat. The penalty is that I only hit around 36 mph with a full boat but we are into skiing. I leave the 15 pitch on all the time b/c the boat doesn't ever struggle to tow.
i believe the 90 is rated for 5250 rpm - so you want to prop it as close to that as you can - maybe 100 over is OK too. Michigan makes good props for the force some props require the anode to be taken off depending on what lower unit you have.
