Tacklewasher
- Joined
- Sep 18, 2002
- 1,588
Testing props today.
18' Starcraft SS with an 1981 Evin 115. Motor is raised as high as possile.
13X15 Stilletto SS prop.
37.9 mph (gps) at 5500 rpm. Never had a question on the tach. Motor trimmed all the way up.
I calculate that as 3% slip.
Same setup but with a 13X17 aluminum OMC prop gave me 38 mph at 5100 rpm. That calcs at about 7.4% slip.
So the 400 rpm difference makes sense but I sure seemed to pick up efficiency with the stainless prop. Hole shot is great and runs well throughout the whole band. Had some venting in turns, but no venting while running straight. Bit choppy so I would not be surprised if I can get more speed/rpm on calm water, but unless I've done something wrong with the math, that is pretty freaking good.
I've done a full decarb (man that makes a big cloud and I forgot the back door to the house was open) but the carbs could probably use a rebuild as I did it last 4 years ago. But for now it's time to buy a prop lock and figure out how to go fishing.
