3 to 4 Blade RPM Change Expected
Ernest T
If I go from a 3 blade to 4 blade prop with no change in pitch, how would this change the RPM. What if I drop 1 in pitch going from the 3 blade to the 4 (17p 3 blade to 16p 4 blade). Presently running 5800 max RPM with 3 blade 17p ss prop on Yamaha F150.
Thanks
Leardriver
Re: 3 to 4 Blade RPM Change Expected
All prop designs are not the same, but if all else were equal, you would lose 150 rpm.
Ernest T
I'm looking at a Powertech prop. I've heard that when calculating pitch with their props, you have to add 1 to the pitch (for example a 16 pitch would run more like a 17 pitch from another manufacturer due to the design of the blades).
I've sent my specs. to Powertech and they have given me 2 prop choices: either a 15p or a 16p 4 blade ski max (MQ4) series prop. I'm trying to decide which one to go with. I was worried that the 15p would result in too much RPM increase (I'm already pretty close to the max at 5800 RPMs with 6000 the recommended max with my current 3 blade prop).
What do you think?
