Re: 3 wire vs 4 wire fuel pump
It's been a lot of years since they changed from 3 wire to 4 wire alarm circuits. The purple wire powers the electronics for the NO OIL alarm and if it is left off, then I believe that your alarm will not work correctly.
The older 3 wire alarm used a rectifier circuit in the electronics to tap power off of the tachometer signal. That is why the system was changed to 4 wire because of the problems getting an accurate alarm when needed as the rectifier circuitry was subject to malfunctioning from voltage spikes from loose battery cables, etc.
