I have an 84 johnson 30 HP, while running WOT for about 10 minutes the motor bogs and dies like it is running out of gas. After it sits for about 5 minutes it will run good again for 10-15 minutes then die again (fuel pump just replaced and did not solve problem).
I checked the primer bulb when this happens and it is collapsed and can not be squeezed anymore, if I cut the throttle back before it stalls and can pump the primer bulb a little to get gas back in it, then it will continue to run??
Could the problem be fuel tank connection or fuel line and primer bulb?
