89 30hp Evinrude. This motor sat for 5 years. I have replaced - all fuel lines, primer bulb, fuel pump, primer selonoid, water pump. I cleaned the carb and did a kit. The float is set at level minus 1/16" with 3/4" drop ( the old float was set at level minus 1/4" with 3/4" drop). I only had spark on the top cylinder (#1?). Replaced the power pack,ignition coils, plugs and plug wires. I now have fire on both plugs. The motor has a slight miss at idle with the muffs on. when I power up it boggs down heavy then trys to accelerate in at about 3 second cycles. Once or twice it powered up normally to wide open, decellerated to 1/2 throttle normal then cycled when decellerating back to idle. Tonight I,ll check for the correct wire placement from the power pack to the ignition coils. The charge coil wires to the power pack were both brown/green I may have reversed them. Would this make a differance? I understand that the woodruff key positioning under the flywheel can affect the timing but I never removed it. I didn't have this problem back when it was running on only one cylinder it accelerated pretty smooth for one cylinder. Any Ideas?
