302c.i. pulley collar / sleeve
jstaszko
I have a 1973 Starcraft American with a Waukesha 302. While on the lake today we heard / felt a little thump followed by some jangling noise. After poking around I found this... collar (?) that seemed to have broken loose from the back of the main pulley. I can't see or tell how it was ever attached or what it's purpose is. I'll get some pictures posted tomorrow. But does this ring a bell with anyone with 302 experience?
Ayuh,..... Sounds like the harmonic balancer separated,.....
Replace it with a new one,.....
depending on the amount of room you have, you may need to pull the motor to replace the balancer
jstaszko
Thanks. Newbie mechanic question, is the harmonic balancer connected to the pulley or drive shaft? I "think" I have enough room. (engine is a 302).
the pulley would be bolted to the harmonic balancer
the harmonic balancer is on the crank shaft
you need to use a balancer puller, available for loan at your local auto parts store. you need to have about 8" of room in front of the balancer for the puller
jstaszko
I called around a few parts stores, the replacement part has a 4 bolt pattern, the pulley assembly is a 3 bolt.
Bt Doctur
jstaszko
Great document, but I am still having a heck of a time finding a replacement.
Ayuh,..... Are ya searchin' for a 1973 Ford 302 balancer,..??
Or,....
A 1973 Waukesha 302 balancer,..??
The Ford part oughta be easy peasy,....
jstaszko
Or,....
Ford, the parts I removed (balancer and pulley) have Ford logo stamps. As for easy peasy, not so much. All the parts places tell me the replacement for a 1973 302 balancer is one that has 4 holes for the pully, mine only has 3.
kenny nunez
There is a service that rebuilds harmonic balancers. There is an ad in the Hemmings Motor News at the larger book stores.
jstaszko
