30hp 4-stroke operation
belairbrian
Just got this on a bass tracker and do not have an operators manual. Could someone answer a few questions.
It is a 2010 console steer.
What is the little red light on the front? Lights on start up then goes out after a few seconds. Thinking it is oil pressure but not sure.
It seems the ECU handles could start as the remote is shift and throttle no disengage or fast idle. Is this correct?
how long should the motor warm up before throttling up? PO recommended 5 minutes. Can this be done idling through the no wake zone?
What is the pull start process if starter fails?
Bass Pro is trying to get the manual. The online parts places are showing it obsolete.
carholme
Re: 30hp 4-stroke operation
What is the engine s/n? I am pretty sure that I have the one you need.
Gerry
