My dad has wat he calls (earmuffs) its basicly how it sounbds, but u can connect them to a fresh water hose.. and it flushes ur engine
Well, that style of engine doesn't work with earmuffs unfortunately, but there are other types of attachments that have been used. I've seen posts on here where people have made up their own and had great results.![]()
That's a yes and no .... I had a pair of '58 ERude Bigtwins (same midesection as the 28/33) on my boat for awhile and used to run them on modified muffs frequently. All you have to do is to take a standard, rectangular muff and cut about a third of it off, along the long dimension. When using it, put the cut edge down, resting on the top of the cavitation plate. It will leak quite a bit, but if you have sufficient hose pressure it won't matter - the engine will still get plenty of water.
Thanks jay, that solidifies my point exactly. Any muffs you use on these motors need to be modified, or you'll starve the motor of water and nuke out the impeller.![]()
For my '57 Lark, I took an extra intake plate and drilled a couple large holes in it toward the top of the plate. I switch that plate out for the standard one when I want to run it on muffs, and the muff fits over the holes without any modification to the muff. The intake plate is only held on by 2 screws and only takes a minute to change it. Works fine.
