Got all the electrical done. Plugs, wires, coils, points, condensors, new key switch. New impeller, new fuel lines, new fuel pump. Fresh gas. Hit the switch and it fired right up. BUT, it wants to sputter a little and then backfire and die. I did not go through the carb. I do have a kit but I wanted to see if it would even run before going to that trouble, but I did spray it real good first. So, hopefully this is just a carb cleaning and rebuild problem. Any other ideas besides the carb? I'm not really up on points ignition. The way I set them was to turn the crank to the highest position and set to 20k. Then did the other set the same way. Was that right? Also, starter bendix stuck in up position. Easy fix? Or new starter?
