35 HP 1977 gearcase internals ?
G DANE
I am putting a motor together from different parts. I have 1 gearcase from 1984, complete, but jumping out of gear, and wobbling propshaft, one gearcase from a 1977, perfect working order, but no driveshaft. The 1984 driveshaft has different number of splines than the 1977. My question is, will the 1977 gears ( except from pinion gear fit into the 1984 gearcase ?? I never had a gearcase of that type apart, do the bolts that holds the bearing carrier tend to snap ?? How to deal with it if it happens ??
Chinewalker
Re: 35 HP 1977 gearcase internals ?
No, the gears won't swap out - they units are quite different internally. Gears, propshaft, clutch dog, etc. are all different...
- Scott
G DANE
Thanks Chinewalker, too bad - I will have to open up the 1984 gearcase and try to fix it, then. Hope those 2 bolts deep inside wont snap, then. Are they usually hard to get apart ?
