Re: 35 hp evinrude gear oil
just means it hasnt been changed in a while. You can use the kerosene like stated, or diesel fuel to flush it. Make sure you change the vent and drain screw gaskets as well.Keep an eye out for metal filings on the drain screw, it is magnetic. Good luck
