35 hp Johnson Sea Horse
sam glenn
Can someone tell me what year this model is? The serial number is 1985802 and it is an electric start 35 hp. If it helps, it is on a 1960 Starcraft "Bonanza Deluxe"<br /> My problem is that the wiring harness from motor to console is shot and I need a new/newer one....<br /> Any help out there would be appreciated...<br /> Sam Glenn<br /> at stevien@hotmail.com
Joe Reeves
Re: 35 hp Johnson Sea Horse
LilSam.... There should be a "Model" number on the same plate/area where you got that serial number. We need the model number to determine the year.
sam glenn
to joe reeves:<br /> the model # is RDSL 21 B for my 35 hp Johnson Sea Horse...<br /> Thanks for your reply and your help<br /> Sam<br /> stevien@hotmail.com
JB
Howdy, Lilsam.<br /><br />Your engine is a 1959.<br /><br />Good luck.
Lark40
Wiring harnesses for for engine appear on eBay from time to time. Of course, how much better they are than yours is the question.<br /><br />You can easily make your own homemade wiring. The correct diagram is in the Clymer Repair Manual for 1956-72 Johnson/Evinrude Engines, which has a link at the bottom of this page.
bhalsdorf
Lilsam,<br />I have a couple of those harnesses in good shape with the junction box. junction boxes are blasted and repainted. Also have a new starter solenoid installed. I also have one where I had to replace a couple wires and put new tubing over the harness. If you have trouble locating one e-mail me at bhalsdorf@mecanex.com and we can come to some kind of arrangement.
